Help! Gettting my butt kicked by Gophers
SuperCyrix
2,118
They're destroying my Garden. I've tried smoke bomb but they survived and it's a pain in the butt digging for those holes.
Any experienced Golpher assasins around here?
Fausto
26,521
You need two or three small, angry terriers. Just the thing for routing vermin. ;)
Mister T
3,439
I remember a thread about a year ago posted from another site... it had like 200 posts and was hilarious... I forget if is was gophers or woodchucks
Viper GTS
38,107
433
- A large hat
- A chair
- A 12 gauge
- Patience
Apply above resources in the early morning and late evening hours.
Repeat as necessary.
Viper GTS
narzy
7,006
Originally posted by: Fausto1
Originally posted by: Viper GTS
- A large hat
- A chair
- A 12 gauge
- Patience
Viper GTS
LMAO! :D
he's not sh!tting, thats the best way. next best way is traps, theres this cage like device that will chop their heads off if they decide to pop their head from out there hole works quite well.
ElFenix
102,407
8,595
the bet scene is the one where he was talking about the grass he invented... whole thing was improvised... awesome
AU Tiger
4,280
I have heard that spraying the area with castor oil may do the trick with moles. I don't know if it works with gophers or not.
Viper GTS
38,107
433
- A large hat
- A chair
- A 12 gauge
- Patience
Viper GTS
LMAO! :D
The problem with automated systems like that is there's always the danger of catching your cat, the neighbor's dog, or (even worse) your neighbor's little kid.
If you're going to use traps, make sure they're covered so they're not accessible. Turn a wheelborrow upside down over it, or something, but make sure you don't hurt anything other than what you intend to.
That's the nice thing about the shotgun, it's quite effective and completely safe.
Viper GTS
vi edit
62,484
8,345
That's why you use live traps. Catch something in it - if it's a cat, you let it go. If it's a gopher, you shoot it.
SuperCyrix
2,118
[Q- A large hat
- A chair
- A 12 gauge
- Patience
[/quote]
OMG! Didn't I see that on an episode of Married With Children when Al Bundy was trying to catch dat wabbit?
I like to go for the trap, but I can't find any holes. don't know if they're moles or gophers though.
Sundog
12,342
Go to home depot and spend $1.50 on a leg trap, look for the freshest dirt pile and follow the instructions.
desertdweller
588
I heard on the radio that some people in Texas are doing what they called
Gopher "Fishing".
You get your fishing rod and make a slip knot in the end. Put the circle fishing
line around the gopher holeand go wait. When he stands up, yank and reel.
Never tried it, sounds messy.
DD
zzzz
5,498
After you catch them, dont forget to barbecue..
"Care for some gopher? "
MrBond
9,911
How wide are the tunnels they're making? Mole's make tunnels about the width of a baseball that poke above the ground.
If they're moles, there's a couple ways to get rid of them, one of them I'm 99% sure you can't do (because you live in PRC where it's probably illegal). The option you could use is to go to a gardening center and get some Milky Spore. Apply that to your yard and it'll kill the grubs the moles feed on primarily. It's quite expensive though. The second option is an industrial grub killer called "Counter," but the average person can't buy it and it's a little dangerous. It gets in any worms/grubs in the yard where it was applied and kills whatever eats them. Birds included.
If the burrows are bigger then that (like a hole a little bigger than a softball, then it's probably gophers or woodchucks/groundhogs. When used properly, smoke bombs are VERY effective on woodchucks as long as they're in their dens. You have to find both holes (they have an entry and an exit) and bury on of them. Light the smoke bomb, toss it in the other entry and cover it quickly before the smoke bomb goes off. I usually try and hike the smoke bomb as far down into the burrow as possible as well as standing there with a shovel and covering up any leaking points.
Make sure you're getting the special smoke bombs for killing woodchucks too, your 4th of july ones won't work.
IGBT
17,976
141
A sonic gopher thumper..kind a like them things they would pound into the ground in the movie Dune...?
bentwookie
1,771
pour some pee in the tunnel
other than that traps are the only things that seem successful.
I got lucky one day I usually flood the holes so one day I saw the ground moving, flooded the hole and the mole came out...the thing was friggin huge! about 8 inches long. now I have a gopher travelling through the mole tunnels.
Bleep
Out here in the wild west we use rattle snakes, catch a couple and stick them down the holes. they will get them.
Bleep
