- Dec 20, 2000
- 6,457
- 6
- 81
I am running libranet 2.8 (debian w/ a better installer) I have opengl libraries installed. I am running a asus A7N266-VM norce1 motherboard, with the latest nvidia drivers installed.
seth@daedalus:~$ glxinfo
name of display: :0.0
display: :0 screen: 0
direct rendering: Yes
server glx vendor string: NVIDIA Corporation
server glx version string: 1.3
server glx extensions:
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_SGIX_fbconfig,
GLX_SGIX_pbuffer
client glx vendor string: NVIDIA Corporation
client glx version string: 1.3
that is some of my glxinfo output.
seth@daedalus:~$ wolfmpdemo
Wolf 1.1-MP linux-i386 Dec 25 2001
----- FS_Startup -----
Current search path:
/home/seth/.wolf/main
/usr/local/games/wolfenstein-mpdemo/main
./wolf.x86/main
0 files in pk3 files
Running in restricted demo mode.
/home/seth/.wolf/demomain
/usr/local/games/wolfenstein-mpdemo/demomain/pak0.pk3 (1846 files)
./wolf.x86/demomain
1846 files in pk3 files
execing default.cfg
couldn't exec language.cfg
couldn't exec wolfconfig_mp.cfg
execing autoexec.cfg
Hunk_Clear: reset the hunk ok
Joystick is not active.
Bypassing CD checks
----- Client Initialization -----
----- Initializing Renderer ----
Loaded 714 translation strings from scripts/translation.cfg
----- Client Initialization Complete -----
----- R_Init -----
...loading libGL.so: QGL_Init: Can't load libGL.so from /etc/ld.so.conf or current dir: /usr/local/g libGL.so: cannot open shared object file: No such file or directory
failed
...loading libMesaVoodooGL.so.3.1: QGL_Init: Can't load libMesaVoodooGL.so.3.1 from /etc/ld.so.conf al/games/wolfenstein-mpdemo/libMesaVoodooGL.so.3.1: cannot open shared object file: No such file or
failed
----- CL_Shutdown -----
RE_Shutdown( 1 )
Sys_Error: GLimp_Init() - could not load OpenGL subsystem
that was what I get when trying to run RTCW
GLX_SGIX_pbuffer
./wolf.x86/main
./wolf.x86/demomain
execing default.cfg
Bypassing CD checks
----- R_Init -----
failed
failed
RE_Shutdown( 1 )
