HELP!!! Geforce3 Ti200 and MCM2!!!
BAMAVOO
41
I have a GF3 and Motocross Madness 2 studdrs and skips and all..Got it fixed with my Geforce2pro but can not figure it out now..
Nothing OVerclocked in my system...Right now :D
tbird 1.4
kt7araid
the usual...
mistercoffee1
16
What is your AGP aperture set to?
I had to change from 64M to 128 AGP aperture since switching from a GF2MX to a GF3 Ti200. That REALLY sped up MCM2. (I have 256 M Ram total).
BAMAVOO
41
It is not a speed issue..The speed is fine..It is just that it hangs for a spit second and takes off again..It does this a lot..I had it fixed with my Geforce2 pro..Now I can't make it stop :(
strikermlc
23
listen to mistercoffee, he's on the right track.
Try changing your agp aperture in your bios, for me 128 works well, but I have 512mb of ram, you'll just have to test things out to find out which setting works best for you. From what I've noticed so far, the stuttering begins to start when agp aperture is >= half of your physical system memory.
Hope this helps...
BAMAVOO
41
I have tried 64,128 and 256...Nothing changes..I have 512meg o ram...It was setting like No Vsync and something else..Just can't remember..
thanks
bam
