I have relied on the threads from this great place for some time now. And, since it is time I feel I need an upgrade on my graphics card, I personally feel obligated to ask the pros here what they would get.
I currently have a NVIDIA GeForce 9800GT I mostly play World of Warcraft. My wife plays Sims 3 and sometimes I play betas of games that I have been invited to. I just have the feeling that with all the new stuff they are doing in games it's time for an upgrade on the graphics card.
I'm running windows 7http://www.bleepingcomputer.com/forums/topic377647.html# home 32 bit. I have 4 gb RAM, 2.4 ghz
The Max Resolution of my monitor 1440 x 900 / 60.0 Hz but I run it at 1024 x768 / 60.0 Hz.
my computer is a Q6600 2.4Ghz.
Intel core 2 quad
Power Supply 550 Watt Top Power Power Supply
Motherboard Board NVIDIA nForce 630i based chipset, DDR2, mATX, PCI-e
Processor Intel® Core™ 2 Quad processor Q6600, quad 2.4GHz cores, 8MB L2 Cache (+$100.00)
CPU Cooling Intel® Certified Heatsink/Fan, Thermal Controlled Variable Speed Fan
DDR2 Memory 4096MB Corsair™ XMS2 DDR2-800 Low Latency Extreme Memory with Heat Spreader (2x2048)
I had it custom built from Velocity Micro about two and a half years ago. (The time may be a little off.)
I am willing to spend up to about $200 dollars right now but if waiting a few months will get me more for my money is the right thing to do........that I am willing to do.
I was looking at
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121390
but I don't know if my power supply which is here,
http://www.newegg.com/Product/Produc...82E16817101021
will run it.
Thanks in advance for you help friends.
AJ
Intel core 2 quad
I was looking at
will run it.
AJ
