Help from people w/mbm5 and 8kha+
de8212
4,021
Just got my new system up and running so I installed MBM5. Never used it before so I am a little lost.
First of all, on the mbm5 website they list the board as "EP8KH+". At least I think they mean EP8KHA+. So that's the configuration I am tryin to set up.
Under Primary Sensor Chip the website says to pick Winbond83697HF. I can't find that in the drop down list. Am I missing something?
Under Case Sensor I chose Winbond 1. SO that seems OK. I get 20 Celcius.
Then under CPU Sensor, I choose Winbond 2. I get 30 C. So that's OK I think.
So what am I doing wrong with Primary Sensor Chip?
de
SnowPunk98
Banned
Jun 15, 2001
4,933
long as it is the newest version you are good. for the CPU temp use winbond 2 and I belive winbond one is air temp. Remember these are allways pretty far off from the real temp. What kinda cooling you got? I have installed a probe that is touching the side of the core and that reads 31, MBM says 40 but the probe is better
de8212
4,021
<< and I belive winbond one is air temp >>
Not to be picky but you mean air temp inside case, right?
<< What kinda cooling you got? >>
I have a volcano7 and 4 panaflo 80mm fans. Currently the doors are off until I get everything finished.
So should I just go with those two temps or is there something elese I need to monitor?
<< Remember these are allways pretty far off from the real temp >>
Hmmm, I alway thought the were close form the things I have read.
de
de8212
4,021
Also my Voltage is Core0 = 1.78 and my core1 = 1.54. How do I know what these represent?
And Fan 1 = 2596 right now. I am pretty sure that's my cpu fan. I also have the ANtec 400 watt power supply that has a fan connector. I connected it to header labeled "fan3 pwr fan". I do not see any representation of that on the dashboard of mbm5????
de
