Help from any UNIX guru please. ( Update - problem solved )
gittyup
5,036
Here is the problem.
I am doing a grep on a file. I only want lines where the search string is matched exactly.
command % grep exam filename
filename contents:
line 1)here:is:my:exam:contents
line 2)here:is:your:problem:example
The problem is that grep will return both lines because it matches all or part of the search string. Lines that conatina both "exam" and "example" are returned. I only want line 1 to be returned, an exact match. I have looked thru the man pages and I don't see any options that will work. I know it can be done. I am also looking into awk. Any ideas????
aimn
Banned
Feb 14, 2001
683
I dont know the answer but I know who does! Go to HP Forums and post this question. You will have an answer within minutes.
Actually I posted the question for you, so you wouldnt have to go through signing up and everything. Sounds like you might want to do that anyways. So to speed things up, I posted it quick. I will post there answer here.
aimn
Banned
Feb 14, 2001
683
If the word you are looking for is surrounded by a space, or any other character :) ; etc..) then you can do a: grep " exam " filename
KarlHungus
638
If I get the problem correctly then sysadmin's suggestion should work.
grep "exam:" filename
gittyup
5,036
Normally it would, but in this case, you never know what is going to be on either side of exam.
It may be :exam:
or :,exam:
or :exam,:
or :exam,,,:
or :;;exam,:
It varies quite a bit in format. That's why I need to just search for exam exactly how it is.:D
KarlHungus
638
Try using egrep instead, and do the following
egrep "exam: |exam," filename
It should work for the examples you just gave.
Edit - uh oh, pipes made that string mad. There should not be a space after : in that expression.
aimn
Banned
Feb 14, 2001
683
There is an option to grep that will give you only the exact match of the string you enter.
Check the man page for grep.
The -x option returns only exact matches.
gittyup
5,036
sysadmin
Yes, there is an option -x for fgrep. Although, I think the -x option will return if the pattern matches the entire line.
At any rate, I went ahead and coded a "C" solution to the problem. Thanks for all your suggestions people.
MereMortal
1,919
Did you try this?
% grep -w exam filename
Edit: This flag works, but unfortunately it is not standard. It seems to be on Sun OS's but not on IRIX.
