HELP FOR THE LOVE OF GOD! (network problem)
I'm trying to install an ethernet card to get onto my buddy's LAN and we can't get Windows 98 to recognize the card - we're also experiencing random system freezes whenever the ethernet card is in the system physically.
We're trying to install a LinkSys LNE100TX etherfast card
Any help would be extremely appreciated.
Thanks,
Chris
most likely your experiencing an irq conflict when you install the card. try using a different slot to install it. if that doesn't help matters then
a little more info on the system together with a full irq listing would help enormously! 🙂
Hmmm...
All of that IRQ talk is foreign to me, I'm a new guy with computers, basically.
Is the ethernet card having problems with my 56k modem stuff that I still have on the computer?
400 mhz K6-2
20 gig Maxtor HD
64 MB RAM
17 mon.
irq or interupt requests are assigned to each device.. the NIC must be conflicting.. switch slots.. or take out unneeded cards.. like a modem if u have cable/dsl
<< Is the ethernet card having problems with my 56k modem stuff that I still have on the computer? >>
can't answer that specifically as we don't know what irqs those devices are using. what pci cards do you have installed?
if your using win98/ME, look in device manager, highlight computer &amp; click properties. you'll see how your irqs are being used &amp; post them back here!
I finally got the card installed and working, so it seemed. It worked fine for about the first 3 bootups then it stopped working and started freezing again. The BIOS says that the CPU is at 59 degrees, is this bad? Could this be causing the freezing? I will take a look at the IRQ's but I think the freezing might be due to the high temperature. Thoughts?
Another Update:
We got the temperature down but the freezing has not stopped, any ideas? It's down to 44 degrees now.
Is it possible that the program &quot;mprexe&quot; is causing the freezups when Win98 boots up? BTW, the freezeups occur right after Windows asks me to login with a username/password.
Timely response will be rewarded!
