CDC Mail Guy
Bought this case http://www.tigerdirect.com/applications...m-details.asp?EdpNo=1800612&CatId=1508
and installed a cheap $30.00 PC Chips mobo LGA 775 blah blah blah.... I also picked up an Ultra X-Connect PS off of ebay for almost pennies! Great deal, but NO good in case because there is like a 1/2 inch between the PS and the optical drive, therefore I cannot plug anything into it.
Now I need a recommendation for a 300-400 watt power supply with as FEW wires as possible, but it needs to have a SATA connector (1 will suffice) The motherboard has a 20 pin connection. Will a 20 + 4 connection work on it? (and WTH is 20 + 4?) 🙂 I would go with a micro ATX power supply, but I don't think the mounting holes will match the case.
