Help for Older Stuff
Jim123
98
Hi, Need help, This is going back in time, I'm hoping that you guys can help. Because Video Cards of this era are cheep, somewhere under $20.00 can get you a card that back in 97 would be the equivalent of a Geforce4 today, and I'm only looking in the geforce2 range. What cards would you suggest even in the 4mb range. I'm setting up 3 units like this for friends, our company upgraded their PC and gave us these units FREE. The following is my request for information from Compaq Support and their response back. I'm hoping someone can shed some light on this. My goal is to make these PC be all that they can be (but not more). I just know I can do better then 2mb (the upgrade is no longer available)
Thank you, very much
Jim
units specs: PS145W Pen2 233, 66BUS, 32MB SDRAM, 384MB max,
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
This is the e-mail I sent to Compaq Support:
COMMENTS:
Hello, I'm doing a clean install of Windows98se and at this time I would
like to upgrade the video, by adding a PCI plug and play card with about
8
to 16mb of video ram. I found where I can disable the onboard Video
controller, is that all I need do? and can the system handle the
additional 4 to 8mb of video ram.
I could not find anything on this for the Deskpro 2000 6233MMX.
Thank you
Jim
This is Support e-mail back
Thank you for contacting HP eServices.
This is with reference to your e-mail regarding 'Video RAM'.
The serial number (6751BMJ2D472) provided indicates that your system is a Deskpro 2000.
This unit was shipped with a Matrox performance graphics (Integrated) w/2MB of 100Mhz SGRAM. Compaq has not tested 8MB or 16MB of video RAM on this unit. This unit supports maximum of 4MB of video RAM.
However, we would suggest that you download and install the latest ROMPaq from the link given below:
<http://h18007.www1.hp.com/support/files/deskpro/us/download/1056.html>
ROMPaq for Deskpro 2000 (686M ROM)
version 98.12.10 (10 Dec 98)
Download SP8437.exe
Please follow the installation procedure from the link given below:
<ftp://ftp.compaq.com/pub/softpaq/sp8001-8500/sp8437.txt>
Note: You can install PCI card. When you install the PCI card the onboard video card will be disabled automatically.
Given below are the part numbers of the graphics card that Compaq has tested on this unit:
2 MB SGRAM Module (on Pentium II processor models) 270834-B21
Thanks and Regards,
HP eServices
:D
HumbleFish
390
Jim123,
I'm no expert here (double check what I'm saying), but if You have Win98 a Pentium II CPU and a PCI slot I would think that You could put just about any Video Card in there as long as Your system agrees with the Videos Cards system requirements...
You can shop for Video Cards here at: www.pricewatch.com, and You can find Video Card Reviews at: www.reviewfinder.com.
