Hey all,
I'm a bit of a newbie at OC'ing but have read up quite a bit on the topic and am trying to get some more speed out of my P4 3.0c northwood, which apparently can overclock fairly well. For cooling I've got a Zalman 7000B Al-Cu in a Sonata case (Antec 380W Truepower) and my idle temps are REALLY low (around 26-28 C) and load temps no higher than 34-35 after running prime95 for a few hours. Everything is stable at stock (prime runs for hours with no issues), except for whatever reason my default Vcore is 1.2625, which seems a bit low...
Because I'm using generic ram (PC3200) I've always used a divider when trying to OC and my memory therefore is never going over 400 when I OC. My board is a Gigabyte 8IPE 1000 Pro, which I gather is not an amazing Oc'er but I'm only going for 3.2-3.3 so I'm hoping it won't hold me back. The problem is that even when I go a little over stock to say 207x15 (3.1 Ghz) my Prime test fails after about 10 minutes. I've tried increasing the CPU voltage in the bios a little bit (up to 1.35) but according to Everest/CPUz it's still only feeding the processor 1.26-1.28. Has anyone else experienced this sort of issue or has any suggestions for me to OC this guy? Thanks a lot!
