Help, floppy on Antec KS-282
temijun
Hi guys,
I just got this case. It's a pretty nice case. However, I can't get my 3.5" floppy to fit in it. It has one of those integrated floppy slots can u tell me where to get one of these drives?
Thanks,
temijun
Tomer Gabel
13
You should be able to simply take off the front panel of the floppy drive - there are usually a couple of clips that require a push or a pull and then it will come off. Once it's off the installation is as easy as matching the slot on your case to the bare floppy drive.
Good luck.
ride525
1,379
I didn't even take off the front panel of my floppy.....just installed the floppy as far forward in the case as it would go.....seems to work fine...
