Help Flashing DVD Rom firmware
Y22KC
61
I downloaded the latest firmware for my creative 1241e dvd rom. It says extract the files in a folder, then boot into dos to install. Once I get into dos, run the program, it never flashes the dvd rom. It gives me some info on the type of flashware, the author, and that is about it. I waited about 2 min with no results. It says the light on the drive should start flashing. Am I doing something wrong?
narzy
7,006
doesn't sound like your doing anything wrong, however I dont have that DVD rom nor have I flashed a DVD befor just CDburner and CDroms, my advice is to print out the instructions and make a checklist and go over each step one by one.
sorry I can't be of more help but try that.
good luck.
narzy
slatt01
271
The readme from the Bios upgrade for the creative 1241e available here says that you need to run the command FL 1 for Primary Master down to FL 4 for secondary slave.
You can also get a patch to make your drive region free, should you wish to do that.
