I have ordered all my parts for my new build with the exception of fans, fan controller and sound dampening.
The build is as follows:
i7 920 D0 (Hoping to get close to 4.8 - 5GHz)
ASUS P6TD Deluxe
OCZ OCZ3G1600LV6GK 6GB
Seasonic X750
CoolerMaster ATCS 840
ASUS Radeon 5770 (This will be overclocked and replaced with a 5970 when they are actually available)
Prolimatech Megahalems (Ordered it lapped through CrazyPC, prob didn't need to but thought I might do it anyway myself, so why waste my time)
Intel X25-M 80GB
DVD Burner - Plextor PX-880SA
Arctic Silver 5
I am looking to achieve this overclock with as close to inaudible as possible.
I have several questions:
1. If I leave the front 230mm fan that comes with the ATCS 840 and add a Scythe S-Flex 800rpm (SFF21D) on the bottom of the case both for intake, then replace the two 230mm fans on top with 3 of the SFF21Ds and one on the rear all for exhaust, and push/pull again with the same SFF21Ds on the Megahalems, can I get the needed air flow to cool this and push the D0 (Assuming I don't get a dud) as far as possible?
2. Is there any fan controller out there that can control all 8 of these fans? If so, which one? If not which 4-channel fan controller would you suggest I get and I will double up on it?
3. Do I need to replace the fan on the 5770? If so, what route should I go?
4. Is there a "best" solution for sound deadening?
5. I am also looking for a quiet blu-ray ROM and have had no luck getting specifics on sound on the drives. Any suggestions?
Thanks in advance for everyones help and suggestions!
ASUS P6TD Deluxe
Seasonic X750
Intel X25-M 80GB
Arctic Silver 5
