- Feb 21, 2002
- 6,486
- 2,363
- 136
I want to buy a wireless keyboard as a present, but the problem is I can't find a decent one. I just hate non-standard layout, so the layout must be as close to classic as possible, ideally as close to Ultra-X as possible.
Requirements:
1. Ideally, "ultra-x" layout
2. six-button pgup-pgdn block (no double-sized delete key)
3. no funny "fn" functionality
4. thin enter (no "L" shape)
5. multimedia keys are OK as long as they do not interfere with normal work
6. Although not crucial, but I would highly prefer keyboard with slim keys like ultrax
7. Must be RF, no IR stuff
I've done some research, but I just can't find every wireless keyboard there is. So far I've looked at the most obvious choices, but none of them are good. Logitech dinovo has double sized delete key, wireless ultrax has double sized delete key and "fn" functionality, other wireless keyboards that I looked at are even worse. The closest to ideal I've been able to find is benq x800 and x730, however I can't find a decent place to buy x800 and x730 has too much bling for my taste. Can anyone suggest a decent wireless keyboard with standard layout and slim keys?
Thanks.
Requirements:
Thanks.
