- Apr 10, 2000
- 19,579
- 17
- 81
1997 Dodge Grand Caravan 3.3L 201Cl V6 Fl VIN:R
I need to replace the upstream oxygen sensor and when I put it in advanceautoparts's website, it comes back with 4-5 different ones. I'm not quite sure which one I'm wanting (plus I can't tell what the difference is between them). Any help would be appreciated
These are the ones that say are an exact fit for my van:
http://shop.advanceautoparts.com/we...53;-bosch_19370039-p?searchTerm=oxygen+sensor
http://shop.advanceautoparts.com/we...53;-bosch_19370040-p?searchTerm=oxygen+sensor
http://shop.advanceautoparts.com/we...sor-bosch_18470508-p?searchTerm=oxygen+sensor
plus some others.
TIA!
EDIT (09/30):
So I went under the van yesterday, is this the O2 sensor?
plus some others.
TIA!
EDIT (09/30):
