I have a radeon 8500le oem and it has a DVI-S port. I recently bought a second monitor but can't seem to find a DVI-S to VGA adapter anywhere. Can anybody point me in the right direction? Thanks
www.ati.com , newegg, It's a dvi-i to vga adapter. You won't find any looking for a DVI-S. It's a DVI-I if it has a cross shape with 4 holes around. pinout
