Help finding drivers for Diamond MX200
fourtwenty
Help! I can't find drivers for this card anywhere. I need them for windows 98. Every link I come accross goes back to the diamondmm.com website, which is not functional. I found a few websites that want $5 to download them, forget that idea!
Any help would be appreciated.
I "think" one of the later if not last versions was named "ms10706w.exe".
I don't have this card anymore but do have the driver archived, so you'll have to see for yourself if it works. Donate the $5 to your favorite cause 😉
ms10706w.exe direct link (7.6MB)
For A3D support you might also need supplimental Aureal files... I dont' know which/what is needed, but if you can figure that out I might have it too, though it wasn't together with the MX200 driver, I also have a ton of Aureal drivers/files/etc.
Edit:After visiting Vortex Of Sound I realized what the A3D was... Aureal A3D Driver (1.3MB)
If those don't work then here are more to try.
mindless1 is dead on, those are the lastest(and last) driver sets for the MS1/80/200 line.
