Cloudofthunder
Best at $500 or cheaper........😉
Or would it be best to do DIY..
Diy. Parts Express sells kits, woofers, boxes and amps. Or Madisound or Meniscus.
You will get a lot more boom for your buck by diy.
The PE kits are OUTSTANDING. You cannot possibly go wrong there. At 400 you can pick up a Titanic 10" with 250wat RMS amp. Or go nuts at 900 with the dual 12" 950W RMS job.
Personally I recommend you start with a 15 inch or 18 inch sub from the dayton ultimax line but that's probably out of your price range.
I wouldn't. Personally (and this is from experience in my car audio days) I would prefer 2x 6" or 8" subs over one big one, even mounted isobaric to save space. It was my experience it produced cleaner sound with less effort.
Definitely a myth. I've heard terrible subs and owned a ton of them especially budget small sub's. My 8-10 inch sub's don't even deserve to mentioned in the same sentence...
Op there are a lot of audio myths out there. It's why lots of people recommend directly on avsforum as you'll get less misinformation. I've heard this misinformation from a lot of car audio guys not sure why.
It must be true... I read it on the Internet!
Beauty is in the ear of the beholder! 😀 It worked for me, YMMV. And maybe I'm all wet... a lot of the guys running big subs bought cheap ones, and/or cheap amps.... and, granted, this was 20 years ago, too.
