Okay.. To start off, specs are:
AMD 64 3200+
Asus K8V SE Deluxe
160GB Seagate SATA
Antec 550W Power Supply
9800 Pro (around 5950 3DMarks03)
Okay, I upgraded from a 9600 pro to a 9800 pro and I have been very dissapointed. The 9800 pro performs at almost the same exact level as the 9600 pro did, but it gets even worse frame dips. When playing Enemy Territory and Call of Duty, I get a nice smooth 125FPS (locked it at) but I get so many occasional frame dips down to 35-40 which is just unnaceptable. Even at lower settings this happens. I put the 9600 pro back in, and I really dont get those frame dips I got with the 9800pro.
I think there may be an issue with the power connector? I went into a game and played around a little, and tested it, and got the <40 frame dip. I unplugged the power connector, and I was getting the same exact performance with the <40 frame dip. So could it be that since it performs the same with and without the power connector plugged in, that could be an issue? Should it be performing better with the power connected or something? Any way I can test this, if this is the problem or not?
Thanks in advance!!
AMD 64 3200+
Asus K8V SE Deluxe
160GB Seagate SATA
Thanks in advance!!
