help fast !!!!! need answer in 5 minutes
MugenMan
Banned
i need a program that will alow me to use my tv tuner. ive got a older ati all in wonder pro pci video card. and i have to start recording something thats on tv soon !! please help
what about the software that came with the card?
or
search www.download.com for a program that suits your needs
or
goto the ATI website and see if they are doing downloads of the all-in-wonder software, if you dont have it.
if your that desperate, then record it using the good old, reliable VHS recorder, im sure that you have one of them, everyone has one.
Then, if you want it on your pc, you just press play on the video recorder, and output the signal to your ATI card, with the right cables, and re-record it onto your pc.
PowerVCR II supports recording/timeshifting, etc. Or you can use Virtual Dub just to capture from the TV tuner
get ready for some massive video files.
well to late to start recording heh. basically i just want something thatll allow me to use my tv tuner video card. i just would like a program that displays whats on tv and lets me changes channels ! 🙂
