Just finished putting 2nd nforce together and all was working fine, but then started to lock up after use. I then noticed that fan on CPU not spinning.
PC still boots and windows XP loads, so at least CPU is not fried.
It is a retail AMD XP1700 with stock fan.
How can I tell if it is the fan that is broke or the fan power connector on the board.
If fan is bad, do I get a replacement through newegg.com or AMD?
thanks for the help,
Paul
Paul
