I completed my 1st PC Build yesterday(TT Tsunami case and MSI Neo4 mobo) and ran my computer for 10 hours or so and have had no problems. However, I am concerned that my EMI springs are not placed properly.
I have read that the springs should not be in any ports, and none of mine are. However, I also read that the springs should rest "on top" of the jack blocks. Does this mean that no EMI springs should be visible from the outside of the case(i.e. the back of the case)?
If you look at the following picture: http://www.omnicast.net/~tmcfadden/guides/build/IOShield4.jpg
Should those tabs on top and bottom of the parallel port not be visible from outside and somehow be placed " on top" of the parallel port connector? Also, if you look at the ports next to the audio jacks, my USB ports are laid out like that and the EMI springs are touching the metal between the two USB Ports but aren't in the ports themsleves. Is this ok?
I guess bottom line is I am really confused as to what to do with the EMi springs.
Thanks.
Thanks.
