- Jun 9, 2003
- 9
- 0
- 0
Hi,
At work the bastards have some how stopped all DVD players from working.
If I run dxdiag and go to "Display" it shows the following 3 disabled with the "Enable" button disabled:
DirectDraw Acceleration
Direct3d Acceleration
AGP Texture Acceleration
How can I reenable these options?
I have tried reinstalling the video drivers and upgrading Directx, but it hasn't helped.
Also on the weekend I tried installing a PCI graphics card and setting it as my primary display in the BIOS.
The first time Windows booted the card worked fine and I could watch videos. Then I rebooted and something strange happened - the PCI card was limited to 4 BIT color!
It seems there has been some hacks done to Windows to disable DirectDraw on the main video card, and to prevent other video cards from multiple use.
Can anyone help??????
PS I have admin priviledges to the machine
Do not post on our forums looking to defeat the limitations set by your employer on their system. If you want the job, you play by their rules.
AnandTech Moderator
AnandTech Moderator
