help: dvd decrypter and adobe encore
568overclocked
i'm currently finishing up a project on adobe encore and will eventually create a .img file to make multiple dvd copies on different computers. i've used dvd decrypter before for .iso files with no problems. Will dvd decrypter be compatible with the image file created in encore or do i have to strictly use adobe encore to burn.
thanks for the input
if it's in .iso format, then dvd decrypter shouldn't have any prob burning it. heck it even burns xbox isos, don't see why it shouldn't handle encore.
i'm not done with the encore project yet. but once it's completed, i'll be using 3 different computers to burn discs...so that's why i wanted to know if dvd decrypter is capable of writing image files. the main computer can just use encore to burn. but the other two, i was thinking of using dvd decrypter
I thought Nero can burn IMG files? I guess you can also try to convert them using WinISO or something? Ive got a copy of encore but never used it, you sure you cant output in ISO format with it?
Another option.. Burn the first orignal DVD image, then make an ISO of that burned image. But i guess that leads us to step one all over again. hmm, lemme check something out and ill post an update.
Ok, Nero cant do it. You can however, burn the finished project to DVD within Adobe, then, just use that disc to make a master ISO format.
