Help! Dream PC - Confused
eLinux
191
I had my dream machine all set up and everything...$1800 (more or less, after shipping).
Here's what it looked like:
Link
Here's the problem...there's no motherboard!
I *was* going to buy this motherboard along with the computer linked above:
Mobo
Of course, I was not going to buy a refurbed one...but it looks like NewEgg has stopped carrying this motherboard.
I have heard superb reviews of this motherboard from many different sources.
I was actually going to buy the computer a few days ago when I realized the motherboard is no longer sold at Newegg...
So now I am stepping back and looking at my options.
I could just find another motherboard, but I really don't know where to look. I've never really kept up with motherboards as much as other PC technologies. Gigabyte has always been one of my preferred motherboard manuf. Now, the motherboard I was going to buy that they developed is no longer being sold at Newegg.
So maybe I should just get a 64bit processor, I thought. AMD64? It benchmarks amazingly well... It's powerful. It's cool (temperature, that is; compared to the Prescott anyways ;)). But why in the world would I buy a 64 bit processor if I'm going to be using Windows often (yup, don't ask about my username...I still use Linux, but Windows more often nowadays) and Windows only supports 32 bits?
Sounds like a waste of money and a poor purchase.
So I figured I would buy a G5... Man! OS X, in my opinion, is amazing. It's powerful, smooth, beautiful, and it's...well, just plain cool! But a G5, at least the one I'm looking at (keep in mind with a student discount) is going to cost me $2800! That's at least $1000 more than the PC I was originally looking at buying would cost me.
I'm looking for ideas/thoughts/insights on what I should do... G5? AMD 64, even though Windows only supports 32? Or just find a new motherboard for the computer that I have already designed (link at the top)?
I don't know much about the "latest and greatest" motherboards, so if you say I should just stick with my P4 3.2ghz, then please suggest a specific (comporable or better) model... I'd rather not downgrade; one of the reasons I really liked the Gigabyte board because it has so many features.
Thanks!
magomago
10,973
14
I don't see how getting an A64 is a wasteful upgarde when a 3000+ keeps up with a 3.2C and is priced competitively.
So
25,923
17
Wthlon 64 Will be a good option. At that budget you might even be able to go the socket 939 route.
eLinux
191
You're right...it's not really wasteful to buy it. I'd just feel like all the power is going to waste, ya know?
The processor I'm sure if ultra powerful if it was running a 64bit environment. But Windows 64 won't be out for forever.
eLinux
191
Originally posted by: shady06
9800 pro would be a better buy, the powersupply is overkill
I've read benchmarks that state the 9800 pro runs slower than the 5900XT... Dunno for sure, though. Just what I read.
eLinux
191
Socket 939? Haven't heard much about it. Care to provide more details? i.e., is it really worth going that route? Are Intel processors going that route, as well?
Mik3y
Banned
Mar 2, 2004
7,089
lets get this straight first...athlon 64 does not mean it is a 64 bit only cpu. it means it can do 64 bit. in comparison with intel, amd is stronger in the 32 bit environment. i dont see how you can have a dream computer composing of a P4 3.2Ghz. thats not exactly very high end. also, i dont see how you can compose a dream system without even knowing anything about the athlon 64's. you should check out hte compilation of my dream rig in my sig. its about perfect for me. it also costs $10,000 for it all. i just wish i had that type of money! :)
Acanthus
19,915
ostif.org
This is not true by any stretch of the imagination, they are very close in performance, and the 9800 Pro is the clear winner in newer games.
Apr 17, 2003
37,622
link?
the 9800 pro is faster. believe me
So
25,923
17
Definitely not, but down the road, Athlon64s will go that route. If you tend to replace your mobo/CPU at the same time, it's a waste, but if you're going to change CPUs in the same board, it my be worth it.
For current socket 754 boards, I like the MSI and ASUS boards (although I just got my ASUS and it was DOA so I'd lean twoards the MSI boards).
eLinux
191
I know the AMD does 32bit as well.
My "dream computer" is just fine as a dream computer. I'm not going to spend $10,000...
I know plenty about Athlon 64s. Please, don't come to this thread to flame. I'm asking for advice, not insults.
eLinux
191
Thanks for the heads up...'preciate that.
eLinux
191
Only problem with an ATI card is that it is not well supported in Linux...which I still use from time to time. :)
Either way, the graphics card is not a big deal. I'll probably end up getting the ATI, though, just to play it safe...
Nevertheless...does anybody have any really great experiences with a specific AMD 64 motherboard they'd like to share? Any recommendations?
nick1985
27,153
did you see my post?
Apr 17, 2003
37,622
http://www.msi.com.tw/program/products/mainboard/mbd/pro_mbd_detail.php?UID=572
eLinux
191
Yes I did...I'm certainly not ignoring your post. You have a well-priced and good system there...:)
I'm simply looking for as much feedback and as many ideas as possible. :)
wetcat007
3,502
Just get a GeForce 6800 GT, problem solved it's faster than both :)
Mik3y
Banned
Mar 2, 2004
7,089
the gt is actually cheaper...you can get it for $300-350 at if you search well enuff. :)
Mik3y
Banned
Mar 2, 2004
7,089
than the x800 pro.
nm, i thought he wanted to get the x800 pro. sorry, read wrong.
eLinux
191
...bump for more mobo suggestions.
I'm actually now leaning towards an AMD 64. Is the FX really worth it? The FX53 is fairly expensive, but the AMD 64 3400+, and maybe even 3500+ is (although more than I was thinking to spend) not badly priced...
What major advantage does the FX provide?
