Help! does this PSU have a 6pin pci-e?
song414
230
Hi i saw this in the hot deals thread and this looks like a good PSU for my system
http://www.radioshack.com/product/index.jsp?productId=2179650&tab=summary
its only 10$ after rebates and it seems like a good quality psu.
It has 32 or 34A on 12v which is good. Cant remember which. It has many cables as well.
here is a review of it
http://www.pcstats.com/articleview.cfm?articleID=1719
at the bottom of the page it tells you what kind of plugs it has in this link.
http://techreport.com/reviews/2004q4/psus/index.x?pg=1
My comp:
opty 165 o/ced
asrock dual sata 2
x-fi extreme music
2x 120mm fans
1x 80mm fan
3 HDD's
dvd-rw
floppy
1900xt
2gb ram
would this be enough to run my system? Also would it be able to plug into my video card without using converter plugs?
I know it needs a 6 pin plug but this does have a 6 pin plug but its not for pci-e its a AUX plug. Is that the same?
DaRkLoRd666
82
no, but that doesnt matter, you get the pci-e power in the graphic card box, if it does not come with the box you must contact them (evga, abit, msi etc...)
GrammatonJP
1,245
You should search around before you buy.. the ultra did not seem to have good quality control.. but that could have all been resolve by now..
LTC8K6
28,520
1,576
It doesn't appear to come with the PCI-E connector, but your video card will have an adapter with it. The adapters can also be purchased.
song414
230
well considering that i can get one for 10$ im not complaining. Its much better than the one im using now too.
