HELP!! Does Asus repair motherboards???
SpongeBob
2,825
Alright, here's what happened, I was removing my FOP32 and I accidentally scratched the PCB on my A7V. Now it will not find my RAM. I rememeber someone told me once that Asus will repair motherboards for a fee. Is this true?? If so what do you have to do??
spaceman50
7
Back in 1997 had Asus mobo in 7 month kept killing harddrives ;-(
I sent board in with $20. got it back " they updated BIOS "
that is all the info I got from them . I emailed them every week
for 8 months never got an reply ......;-(
Check this page out -----------> http://www.dma.net.au/asus_news.html
good luck
You might want to try deffoger kit an repair that scrape your self
Spaceman50
Spoooon
11,563
203
A trace on my CUSL2-C burned up. Luckily, some jumper wire and solder was all it took to fix it.
SpongeBob
2,825
Thanks, I though about the defroster kit actually but am not to confident that I could actually get this method to work. Anyone else got any ideas?????
Dulanic
9,969
592
Yes they will, call the RMA department.... its on their webpage... its the US Marketing Department phone #... when you call there is a RMA and Tech Support option, they can help you out.
DaddyG
Banned
Mar 24, 2000
2,335
If you see the damaged trace, any good Mom and POP PC shop or Electronics shop should be able to fix it. Course, most have like a $70 minimum charge.
Wik
2,284
You could send the board to me and I will tell you if it can be fixed, and if not I will be happy to throw it out for you ;) j/k Really if you can see where it is damaged you should be able to fix it yourself or find a friend that can. I repair commercial laundry and dry cleaning equipment and there is this one hotel that has some big dryers that are burning up traces on a circuit board every other year or so. You cant get the boards anymore so you should see my all of my jumpers I have had to install over the years :) But it still works.
kimagurealex
according to the place i bought my mobo from, central computer, the one located in the Santa Clara, CA. They told me that ASUS only deal with dealers. not end user. so, i have to take it back to the central and get the RMA and then they send it to the ASUS and wait for at least 5 weeks (last time, it was 2 months) to get my mobo back.
Alex
Dulanic
9,969
592
<< according to the place i bought my mobo from, central computer, the one located in the Santa Clara, CA. They told me that ASUS only deal with dealers. not end user. so, i have to take it back to the central and get the RMA and then they send it to the ASUS and wait for at least 5 weeks (last time, it was 2 months) to get my mobo back. >>
Not true, I have a MB in with Asus right now for RMA. I called Asus, talked to the RMA department, they asked for the serial # and the problem and gave me a RMA #.
SpongeBob
2,825
Cool, I'm gonna try calling them tomorrow since I have the day off work. Wish it was an 800/888 number though, the phone call will probably be the most expensive part of getting it fixed!
michael2
118
ASUS has a 3-year warranty like Intel.
ASUS does try to get consumers to return motherboards to the reseller first though.
The 3-year warranty is one of the reasons I bought an ASUS motherboard to replace my ABIT motherboard.
ABIT only has a one-year warranty.
