Hi,
I have run into a problem trying to install my projector, all help and ideas are greatly appreciated.
basically i am trying to hide all my cables behind the drywall, however, i discovered that the projector is actually mounted above my "ceiling". since i have a vaulted ceiling, where the projector is going is actually above the real ceiling line. So when i try to drop the cables down, it is being blocked off by my ceiling "joists". I think that's what they are called, they look like 2 2x4s mounted with 4 inches being vertical.
from the pictures below you can see that there appear to be an existing power outlet that is skinny enough to go between the 2 joist boards. however, i can't fit anything big (my power plug and/or DVI plugs) through the space. the drywall pretty much goes right up to the joist board, so i am out of ideas where can i possibly fit those cables and connectors through.
I need to fit the standard 3 pprongpower connector, DVI connector, through it, so my projector can be on the ceiling and all the wiring will run in the wall down behind my sofa then come out of the wall there.
behind the wall is another room. from the way i have cut the drywall already, i hope you guys can tell that i am a total amateur, any advice with low difficulty would be greatly appreciated.
can this DIY project be saved? or should i cut my losses and put my drywall back.
pic 1
pic 2
pic 3
pic 1
pic 2
pic 3
