I formatted the HD to NTFS after transferring everything over to another HD. As the Win XP pro CD is loading it will occasionally pause at a driver and just completely stop. The CD drives do work. I pulled one from the other computer and I have a brand new Lite On 52x CDRW and it gets the same thing. Sometimes it does fully load all the drivers and after opting for a clean install it bluescreens me and says it has detected an error recommends that i disable caching and shadowing ( which i did) and requires a restart. I used Clone CD to duplicate the CD and it gives the duplicate the same problems. I have used this CD install Win XP pro on 3 other computers and had no problems whatsoever. I have used this CD to install Win XP pro on this very same HD in another rig with no problem. The jumpers are not the problem, it is set to cable select, and I had no problem installing the OS on my other rig with it in slave and in master mode. I have been working on this for 12 hrs now and I am getting really pissed. The HD does work, it works fine, the CD drives are fine, the cables are right I have quintuple checked them, the mobo is detecting them, the jumpers are set correctly too. Do you think opening up my other WD SE and trying that would work? Could it be the mobo? (MSI KT333 Ultra 2 )
I know someone can help me please!!!
