N NYer Junior Member Feb 15, 2001 18 0 0 Mar 6, 2001 #1 Has anybody connect digital output port of cdrom/dvd to sound blaster live value? What kind of cable do you use? Thanks
A ApacheXMD Platinum Member Oct 9, 1999 2,765 0 0 Mar 6, 2001 #2 it's just a two pin cable. your local computer shop should have them for about a buck. -patchy
W Wik Platinum Member Mar 20, 2000 2,284 0 0 Mar 6, 2001 #3 If you are real carefull you can take a razor and spit a 4pin one in half and use the half that has 2 wires.
