HELP! Differential Equations hell!
Brian23
Banned
I'm really struggling in this class. It seams like the professor is making it harder than it needs to be. I've been trying to solve this homework problem, but I can't. If anyone can help, I would apreciate it.
given:
g(t) and p(t) are functions.
g(t) != 0
u'(t) + p(t)*u(t) = g(t)
Determin if y'(t) + p(t)*y(t) = g(t) when y(t) = 2*u(t)
given:
g(t) != 0
uhh....ok if y(t) = 2*u(t)
then
y'(t)=2*u'(t) and substitute it in the equation
y'(t) + p(t)*y(t)... and you'll find out that it's not equal to g(t)... I think you're looking way to deep, this question is simple.
given:
g(t) != 0
then
hmm...i just did some quick work on paper and I found that it does equal g(t) when y(t) = 2*u(t).
edit: actually, i reworked it, don't think they are equal given the circumstances.
