I am a newbie at assembling a PC and hence this question.
I purchased an Intel 2.8GHz (800MHz FSB) retail boxed processor. It did not come with any tube or container with thermal paste. The heat sink and fan had a black colored patch in the middle which contacts the CPU.
1. Is this black patch a thermal pad/paste? Do I just mount the heat sink fan on the CPU without doing anything else?
2. Am I supposed to purchase thermal compound and apply it to this black patch or processor before mounting the HSF on the processor? If so, what compound is best?
3. Am I supposed to scrape off the black patch and apply a thermal compound to the processor before mounting the HSF? If so, what compound is best and how do I scrape the black patch off? If the HSF surface needs to be cleaned after removing the black patch, how do I clean it?
4. The processor metallic surface was not shiny (looks dull or is it tarnished?). Am I supposed to clean the surface with some cleaning solution (what?) before assembly?
Thanks!
Thanks!
