HELP! Did flashing kill my rig?
JaydenChris
203
Please! Anyone help....
I just flashed my LiteOn LDW-811s with a new firmware "HSOQ." It used to have "HSOK." Now when I restart my computer....it just keeps restarting after the windows login.
Anyone know what's going on? How can I re-flash to old firmware without having my computer restart?
TIA!!
JaydenChris
203
No...
I'll try that...
(Noob question...that's simply removing the battery and switching a jumper back and forth right?)
Thanks!
Mik3y
Banned
Mar 2, 2004
7,089
just switching the jumper only, but it wouldnt hurt removing the battery also.
capricorn
219
Does pulling the power off of the LiteOn drive let it boot w/o restarting? (Next best thing to pulling it out completely.) If it does, go into the device manager and make sure all remnants of it are gone. Put the power connector back on and let Windows discover it as new hardware. This works occasionally.
slpaulson
4,414
14
I had a similar thing happen with my A7N8X after updating the firmware on my NEC DVD+R. I ended up RMAing the board.
vailr
54
You didn't leave a disc in the drive, while flash upgrading the firmware, did you? (Bad idea!)
