- Oct 4, 2010
- 1,176
- 3
- 81
I recently slapped together a rig from some older components to run a TV screen in my kitchen.
Parts:
Rosewill Legacy U3-B mATX case
Q9550 on an Acer G41 motherboard (pulled from Veriton M275 system)
4GB DDR3
Crucial C300 64GB SSD
Asus GTX 630
Seasonic M12-II 620W
Everything seemed to be working fine, but then it just started shutting down without warning. No BSOD, nothing in Event Viewer except "the last shutdown was unexpected" (ID 6008).
It's happened three times now. I originally suspected the OEM PSU (also from the Acer Veriton), so I replaced it with the known working Seasonic, which I got from a friend. The system was up for four days, but then this morning when I went to use it, it had shut down at 3 AM.
The machine was in a closed cabinet, so heat could also be the culprit, but I've been monitoring temps closely and nothing seemed unreasonably high, with CPU idling at 45 degrees max, and 50 degrees max from the hottest mobo sensor. The shutdowns also happen when the system is just idling.
Anyway, I moved the computer to a new location, although it's not as convenient as the cabinet (much lower WAF). I just moved it this morning, so I guess it's wait and see what happens.
I'm wondering if anything else could be responsible for the shutdowns. The problem didn't happen until I upgraded the memory from 3GB to 4GB (different set of DIMMs, which had been working fine in another machine), but I can't ever recall hearing of a complete shutdown due to a memory incompatibility.
Any ideas?
Parts:
4GB DDR3
Asus GTX 630
Any ideas?
