random betrayal
For a little while now on occasion my monitors will not wake up from sleep. It has happened both from waking the computer from sleep and when the computer is on but the monitors have just gone to sleep. The monitors are working fine otherwise.
Secondly I had a check-disk error recently and windows 7 found and fixed the issue. At least the fix allowed the windows update to finish.
Yesterday I try to wake the monitors while the computer was on, nothing. When this happens the only way to wake them has been a re-boot.
I reboot and no monitors again. A couple more re-boots and still no monitors.
I would assume that this is a video card gone bad as the computer posts. Although once the computer is on it does not show on the network which leads me to believe there may be something else gone wrong that I can now not see.
Any ideas.
Any ideas.
