Hi guys. for literally years, we have struggled to get our internet at home working reliably. we have gone through about 5 routers, dont even know if that is the problem yet, but when we get a new one, it seems to work for a little bit and then the net stops working..
basically, we have two problems-
1. the internet is unreliable and the router will drop its connection quite often which often a reset of the router fixes this, or just time. we are going to a new ISP soon so dunno if that will help.
2. the wireless is temporamental as all hell! dunno if its the wireless cards in the laptops- we have a sony and a asus and the asus works on the wireless much better than the sony. i even bought another wifi ap but even then the wireless drops out and stuff, and often on the asus, just turning the on/off switch of the wireless can fix this.
anyways.. just bought a new linksys wireless router with a built in modem (as i thought the modem could be dodgy and making the internet flaky).
Now im sitting right next to the router and the laptop is scrolling between "authentication process to network has been started". "then it will go "out of network range" and then "searching for nearby, "wireless networks found", "you are now connected".
I just thought that our old routers wireless antenna was dodgy which is why we bought a new one as beeing only a couple of feet away would have poor reception.
computers that are hard wired to the network are fine- they work even if the wireless doesnt but when the internet drops, they dont work (in the router status, it says that it is NOT CONNECTED).
can someone please offer some solutions!
please tell me if any of these situations are possible and making the network are bit dodgy-
1. apparently we are the last house that can get broadband as we are just over 5km from the exchange. any truth to this?
2. would having the router on top of a computer make the wireless stuff up? its only been their a few weeks, but the wireless was pretty dodgy before this.
any help would be great.
