Help, Desktop is gray like using Standard VGA drivers setting
Flatbroke
721
I just got a computer finished, and installed NVMax to do a little boost = 215/425, to my VisionTek G3 ti200, didn't see much difference in game FPS, so I set NVMax back to default 175/400 and started Fraps, to check my frame rate again, and started IL-2, and got a blue screen. I re-booted and now the desktop is gray like when you use the standard VGA drivers. I tried re-installing the Geforce 3 drivers, 22.80, and it still looks the same. The only thing that I can think of is to see if system restore can fix it. Any ideas?
BTW, I tried video card in another computer and it works ok.
Basie
634
Did you reset your refresh rate from 60mz. I think when you reinstall drivers that has to be checked.
