help designing computer
eurovw
119
Well, it's been awhile since I assembled my computer, 2 years to be exact, running AMD 3800+ dual core. So, time to update, I mean to build a new one.
Budget around $1000
no monitor, keyboard, mouse or speakers required.
AMD or Intel system, 2Gb memory, average size disk, win vista ultimate, video card, sound could e onboard.
Primary use is for web design, video (not editing), photoshop, games, business, internet.
Help me out! Thanks in advance
OdiN
Banned
Mar 1, 2000
16,430
What are you planning on using that you already have? Do you have a case and PSU already? What wattage?
We need more details.
eurovw
119
the one that I have I'll give to my little brother, so no components will be used from the present one.
Seems like Intel is the way to go right now, judging by what I have read. But i am still open to idea of using AMD processor. So many things chaged in 2 years!
DSF
4,902
What kinds of games do you intend to play, and at what resolution?
bamacre
21,029
eurovw
119
Want to get everything today from newegg, so here is my wishlist:
https://secure.newegg.com/NewV...ndleExist=N&ID=9088287
Still need case, Power supply, HD, Motherboard, DVD-recorder.
Please make recomendations on monitor, memory, and CPU. Need to lower budget a little.
I 'd like to go with 2x2GB memory, planning on Win Vista< next question 32 or 64 bit?
Planning to OC, so please help me select good CPU/MB/Memory combo.
Primary use -> photoshop, web design, dvd recording, multimedia, and of course games.
Thank you.
eurovw
119
come on guys, a little help. Want to do shopping tomorrow.
Help with CPU/MB? Memory combo. Thanks
eurovw
119
Almost final. Please help me save additional $$$ on MB and memory. Memory will be 4GB. And I need help selecting thermalpaste and CPU cooler.
Thank you
Update Antec Nine Hundred Black Steel ATX Mid Tower Computer Case - Retail
Model #: Nine Hundred
Item #: N82E16811129021
Return Policy: Standard Return Policy
In Stock
Mail-in Rebate
$139.99 -$20.00 Instant $119.99
Update ABIT IP35 Pro LGA 775 Intel P35 ATX Intel Motherboard - Retail
Model #: IP35 Pro
Item #: N82E16813127030
Return Policy: Limited 30-Day Return Policy
In Stock
Mail-in Rebate
$179.99 $179.99
Update EVGA 640-P2-N829-A1 GeForce 8800GTS SSC 640MB 320-bit GDDR3 PCI Express x16 HDCP Ready SLI Supported Video Card - Retail
Model #: 640-P2-N829-A1
Item #: N82E16814130300
In Stock
Mail-in Rebate
$389.99 -$20.00 Instant $369.99
Update OCZ GameXStream OCZ700GXSSLI ATX12V 700W Power Supply - Retail
Model #: OCZ700GXSSLI
Item #: N82E16817341002
In Stock
Mail-in Rebate
$149.99 -$20.00 Instant $129.99
Update Intel Core 2 Quad Q6600 Kentsfield 2.4GHz LGA 775 Processor Model BX80562Q6600 - Retail
Model #: BX80562Q6600
Item #: N82E16819115017
Return Policy: Processors (CPUs) Return Policy
In Stock
$279.99 $279.99
Update OCZ Reaper HPC Edition 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model OCZ2RPR8002GK - Retail
Model #: OCZ2RPR8002GK
Item #: N82E16820227231
Return Policy: Memory (Modules, USB) Return Policy
In Stock
Mail-in Rebate
$90.99 $181.98
Update SAMSUNG 206BW Black 20" 2 ms (GTG) DVI Widescreen LCD Monitor - Retail
Model #: 206BW
Item #: N82E16824001095
Return Policy: [LCD] Limited Non-Refundable 30-Day Return Policy
In Stock
Mail-in Rebate
$299.99 -$30.00 Instant $269.99
Update Microsoft Windows Vista 64-Bit Ultimate for System Builders Single Pack DVD - OEM
Model #: 66R-00838
Item #: N82E16832116215
Return Policy: Software Return Policy
In Stock
$189.99 -$10.00 Instant $179.99
Subtotal: $1,711.91
bamacre
21,029
Killing yourself by buying everything at NewEgg.
Also, the 512MB 8800 GT is faster than the 640MB 8800 GTS (GT is a newer card).
PSU is overkill, bigtime. The Corsair 520W is plenty, and solid. The 8800 GT also uses less power than the 640 GTS card.
Memory is extremely expensive. What kind of overclock do you expect from the Q6600? Remember, at stock speeds, it only needs 533mhz memory. You can get a 4GB kit of DDR2-800 for cheaper than what you are paying for this 2GB kit.
I also do not see an aftermarket cpu cooler. Are you even going to OC?
I do not see a hard drive listed. Need one? If so, check hot deals for a $59 320GB Seagate.
eurovw
119
the PS I chose is cheaper than Corsiar after MIR. Does it make sense, or Corsair is more reliable?
bamacre
21,029
That's because you are shopping at the Egg exclusively. ;)
I guess if you don't mind the MIR. Your choice.
8800 GT in stock...
http://www.ewiz.com/detail.php?name=XFX-88GT51
You may want to get two of these...
http://forums.anandtech.com/me...=2116041&enterthread=y
(2x2GB for less than $100 shipped)
eurovw
119
seems like only CPU cooler left, which one would you reccomend?
Tuniq, XP120, Zalman&
Thank you
eurovw
119
THIS IS FINAL:
Antec Nine Hundred Black Steel ATX Mid Tower Computer Case $119.99
ABIT IP35 Pro LGA 775 Intel P35 ATX Intel Motherboard - $179.99
XFX 8800GT 512 MB video card $300
OCZ GameXStream OCZ700GXSSLI ATX12V 700W Power Supply - $129.99
Intel Core 2 Quad Q6600 Kentsfield 2.4GHz LGA 775 Processor $279.99
Crucial Ballistix 2 GB (2x1GB) x2 (total 4GB) $119.98
Windows Vista 64-Bit Ultimate - OEM $179.99
Seagate Barracuda 7200.11 500GB 32mb cache $124.99
ASUS 20xDVD burner $39.99
Tuniq Tower 120 CPU cooler #44.99
Also deicded to upgrade monitor and speakers:
SAMSUNG 206BW Black 20" 2 ms (GTG) DVI Widescreen LCD Monitor -$269.99
Logitech z-4 40 watts 2.1 speakers $69.99
