HELP!!!: Dell Dimension 4500 Motherboard manual needed
Help!!! I swicth cases and have no idea what the PINS on this motherboard meant without a manual. Somone with experience please help!!!!!! I have no idea to gte my PC working again....please help
I hope you took it all to a new case, dell's dont use standard ATX power supplies...also, try the tech support forum
Not hard. Go to Dell.com. Click on search. Put in "Dimension 4500 users manual" (without the quotes). It should bring up 4 results from the Tech Support portion of their site. You should find some help there. HOWEVER, as was (sort of) mentioned you could have a major problem on your hands. As mentioned Dell does not use a standard ATX Power supply NOR motherboard. The mountings are different as are the I/O locations. IF you could get it in a standard ATX case you would kill it if you got it hooked to a standard Power Supply.
If by chance you managed to get another Dell case to put it in, you might be able to get it to work but it's a crap shoot. Sorry.
