Help deciding on a GeForce 2 PRO Version
jklesel
30
there seem to be a lot of different versions made by motherboard manufacturers. i was wondering, is there any difference between them? i was looking at this version of the PRO by Velo City. Do any of you experts on this have any info on this card. oh and i dont plan on overclocking. thanks for you help in advance.
sep
2,553
This looks like a good buy. However, I've never heard of this company. I purchased my Gainward G2 Pro450 (same 4.5ns ram) for around $130. I then added RAM-sinks for about $15 (red to match the card) and might add a Orb (red) to match the card, $15. This added up to around $160, you can get the samething with the Orb for less than $100. That's a good buy.
However, I would look at getting a card that supports Dx8. I believe the G2 ti200 will utilize Dx8.
Pacfanweb
13,155
59
The GF2 TI200 has nearly identical performance to the Pro, (actually minutely higher) and currently is 11 bucks more. No brainer.
Survey23
50
I think the ti200 would just equal the gainward geforce 2 pro...it is extremely overcockable...hell that is what it is marketed for...
Unless you are willing to spend 40-50 more to jump to the low end gf3 ti200 get the gainward GF2 pro /450...golden sample that is....
default clock 200/400
experttool's enhanced 220/444
I run 225/450...never seen an artifact even after several hours...
This card can go much higher as I have played around and hit 230/460...no artifacts
damocles
The Ti200 has DX 8 optimisations however, which the Pro doesnt. What does this mean in 'real terms'?
