Help deciding between these Lenovo ThinkPad and Dell Inspiron laptops - any insight appreciated
calvin2376
7
I need to make a decision on a new laptop and could use help deciding. I'm down to the ones listed in the below table (though if you think I should consider a different one let me know). I don't use this for anything particularly intensive or specific (e.g., no gaming, programming, CAD, etc), this is just an all-around laptop. I would say my main criteria is reliability/build quality - I tend to keep laptops a long time (e.g. 8-10 years) so I want this to last a long time. That said, I would appreciate a nice screen (I do use it for some photo/video editing) and would like decent battery life (though it spends most of its time plugged in).
r/laptops - Help deciding between these Lenovo ThinkPad and Dell Inspiron laptops - any insight appreciated
Here is my current thinking on these - I would appreciate anyone's input/thoughts, personal experience, etc.
  • Lenovo vs. Dell - I like Lenovo a lot, I have one for my work computer and I love the keyboard. I'm leaning that way, but per the below I am trying to figure out why I wouldn't get the Dell...
  • Yoga 9i - I love this and this was going to be my choice (particularly love the design and screen), but I'm concerned about (i) only 16 GB of RAM (I could bump it up but that's $500-600 more) and (ii) lots of reviews say the real-world battery life is very poor.
  • X1 Carbon Gen 11 - I know this is a prior gen but the new one is too expensive. Main concern with this one is the lower resolution screen (obviously has an older processor, but again shouldn't make a huge difference in what I use it for).
  • ThinkPad T14 - This is obviously more expensive and has the same drawback of lower quality screen, but it's on the list because (i) it seems to be basically a tank that would last a long time (and could be easily repaired if need be) and (ii) it comes with a 3-year warranty.
  • Dell Inspiron - The background here is I went to Micro Center to try out the Lenovos and saw the stats on this one and I'm basically trying to figure out what the catch is with this. It generally has the same or better specs than all the others for quite a bit cheaper. What is the catch or drawback with this one? My one concern (other than the fact that I must be missing something) is that it has a lower brightness of 300 nits (which I feel could be an annoyance when using it in a bright room for example).
I hope to buy this in the next day or so, so thanks for all the help!
Captain Kirk
43
It looks like the inspirion is your best bet
better quality and all around performance.
the thinkpad has less capabilities and is limited
I think you will be happier with an inspirion purchanse
18,618
I would steer you towards a Lunar Lake laptop, with a 258V CPU at the very least.
But if you want the best, there's currently nothing better than a Strix Halo laptop. Get the 128GB version. It's not a lot of money and it should last you a good 5 to 8 years with excellent long lasting performance.
