Help decide between monitors
Hitman928
6,186
10,693
So, I have to try and pick a monitor (or a dual setup) for cad type of work. Movies and games are a non-factor. Mostly just want a decent monitor that will put the least amount of strain on the eyes as I will be staring for long periods of time at the screens. For this type of usage, are the cheaper IPS monitors worth it over a TN panel (or whatever other tech)? Budget is ~ $300. So far I have these options, any opinions, anyone know of a better monitor? Thanks.
http://www.newegg.com/Product/Produc...-24260110-L07A
http://www.newegg.com/Product/Produc...82E16824014299
http://www.newegg.com/Product/Produc...-24236288-L03A
http://www.newegg.com/Product/Produc...-24005363-L03C
