Hi all,
I'm a bit stuck, i have been searching the forums for hours, but cant find an answer.
I have some corsair XMS twinx ram which i brought awhile ago (2x512mb) (3200C2 platinum). (on an amd 64bit 3200 system with the k8t neo mobo).
I thought this was pretty good ram (was expensive🙂, but now as i check the timings, its 3-3-3-8, this sounds bad?.
Now i want to upgrade to 2GB ram, i am thinking of adding a 1GB stick of corsair 1GB DDR XMS3200PT(400MHz DDR). , which apparently has a speed of 4-4-4-8 or simular?.
So will this upgrade auctally slow me down?. are these memory timings ok for 2GB of XMS?.
I thought i was buying good ram, i picked the XMS plat over the value ram, but i don't understand why the latency on all of these is so high?.
the main use is for future games, and current memory hogs, video editing, ect.
Thanks for any help.
