Originally posted by: xerocool
ok, i got motherboard monitor, but it doesn't seem to have my motherboard on there (soyo sy-p845), but i checked the temp in bios and it's 47C WHEW!!! but that's still a little higher than i want it.
motherboard monitor seems to have worked for a a little bit, when i first initialized it, it said 47C cpu and 76C for case. but then after a minute or so it went to -23C for the cpu
oh well, anyways, does anyone know if it's ok to use something like artic silver after a cpu has been exposed to the factory installed thermal pad for about a year? i heard the wax on the stock pad fills up the voids, and thus artic silver won't be as beneficial, is this true?
