Help! "Cpu is unworkable or has been changed."
dreamachines
36
Whenever I boot up, I get an error message that says: "Cpu is unworkable or has been changed. Please recheck - CPU SOFT MENU." What does this mean? Eerytime I change something in the bios I cannot restart be computer, I just get a black screen (no video signal.) But when I descahrge the cmos the compuer works fine but the error message shows up again. The cpu does not seem to be overheating too much. It stays around 22 C. I do not know if it is the mobo or the cpu itself. Please help.
Mem
21,476
13
I had this happen once after a Bios flash I just went into Bios & did not change anything & just hit the save & exit key & everything booted up fine after that.
kylebisme
9,396
i saw this when i tried the pencil trick, got some locktite and it went away. guess im just no good with the pencil, meby you too?
Liquidity
796
No, this means the pencil DID work. There is a bios setting called "Speed Error Hold". Set it to "Disabled" and reboot with your overclocked settings. It shouldn't give you that error anymore after that.
