HELP!!!
I tried the pencil trick and it didn't work so I went out and got a defogger repair kit. After connecting the bridges, I ran into the following problem...
I was able to change the Multiplier to x8 and kept all the other settings the same....the system booted so I went back into the bios to change to x8.5....after making the change, my system would not boot. After clearing my bios, I can't seem to change the multipliers anymore.....and if I change the voltage to any other setting expect the default, my system will not boot...Also, when I change the FSB, I can use the system ok but when I restart my system, it seems to not boot...get no signal to monitor while there is power to system and HDD...
Has anyone run into this problem? Could I have possibly damaged my CPU during the first few attempts with the pencil trick?
Any help would be greatly appreciated....
