I'm currently trying to fix a customer's laptop (Toshiba Satellite A45-S121) and I cannot make it connect to AOL using its modem. AOL wont recognize it and it keeps doing "searching for connection" thing forever, and nothign will happen. In the device manager, the modem is there (Toshiba Software Modem) and its network adapter is also there (Intel PRO/100 VE). It's an Intel Celeron 2.8 Ghz, 256MB RAM w/ a 40GB HD. And also its running slower than it's supposed to be at 2.8 Ghz. I've tried running different anti-spyware program such as MS's Antispyware, Adaware, and Spybot. They found little to no spyware or malware. It has Norton Antivirus 2004 installed.
In network connections window, theres NOTHING there. Its Intel network adapter isn't there, and its Toshiba Software modem isn't even there, too. I've tried resintalling the Toshiba modem driver and AOL 9.0 (so it can reinstall dial up adapter thing) and I've got no luck so far. I've recently upgraded it to sp2 and still, nothing. What's strange is that I can use the internet on the laptop with my cable connection at home. All I need to do is to make that damn thing connect to AOL using the modem. Help me out, guys!
