I have a network at work, and a home network, and would like to connect to work from home.
The work network uses an Netopia 7100 dsl router.
For the home network, Thinking of using a linksys cable router befvp41 (to support VPN).
I am pretty sure the 7100 supports VPN.
(It is my business and home so no problems there)
Running NT PTP at work, and XP PRO network at home.
Questions:
Do I need to do it via VPN?
Is there another way to do it?
Is this the right equipment?
Any help is appreciated, as I need to purchase at least a router, and maybe a cable modem, I would like to purchase what will help make this connection work.
Thanks a BUNCH !!!
Questions:
Thanks a BUNCH !!!
