Help: Connecting to managed switch via console cable
Tardy
I feel really stupid asking this:
I happen to came across a cheap managed switch that wasnt configured. I tried to connect the "console cable with DB9-connector" (seriell cable) with the com port of the server. The switch came with a configuration software so I tried to connect to the switch from there but couldnt get it to connect. The switch has to be configured with the seriell cable first or I cant use the web interface to manage it.
What am I doing wrong here? Am I missing something? configuration programm != console? I sadly have not much experience with setting up switches, tho I think I am able to config it after I get a connection at least. I tried different com Ports (tho the software only lets me choce between com 1 or 2).
Anyone? (PS: I tired a different PC too, no changes)
You need to use a serial cable to connect. Depending on the switch it might have to be a null modem cable. From there you can use a terminal program like teraterm or windows hyperterminal.
The switch Make and Model would help. As to your interface, if you are connecting thru a USB to Serial Adapter, you need to get one that is BiDirectional. Not all of them are and some just will not work to configure a switch or a router. You need a serial DB-9 cable as well. Use a program called HyperTerminal to talk to the switch / router. It is included in most versions of Windows.
Settings are: Baud= 9600 Bits per Second .. 8 Data Bits .. No Parity .. 1 Stop Bit ... Flow Control=None
http://www-tss.cisco.com/eservice/compass/common/tasks/task_veri_Config_Hyperterminal.htm
One of these would work well:
http://www.usbgear.com/computer_cab...199&catid=482%2C1303,199,461,106,1009,601
For terminal emulation on windows (XP, Vista, and win 7) I also recommend putty.
You will need to know the speed to set the serial interface to. Chances are its 9.6k or 115k. Other settings are usually: data bits 8, stop bits 1, no parity.
Rob.
Thanks a lot guys. It really was another terminal software I needed. Switch is at least usable now and I already set it up.
Again, I really appreciate the quick help I got here *thumbs up*.
