Hello! I'm very sorry if my question sounds stupid, but I just wanted to make sure everything is right, because I'm slightly afraid of frying my PC... 😛 My motherboard has no Firewire, so I installed a PCI card which works perfectly, but it's very inconvenient because the ports are located on the back, so you keep climbing under your desk. My PC case, however, does have a Firewire port on the front panel, which was never active, but I would really want to connect it to my PCI card. The problem is that my PCI card does have an internal Firewire port, but it looks nothing like the wire which goes to the front panel: http://i43.tinypic.com/xt99l.jpg There are adaptors available which are supposed to help me solve this problem and convert between two different connectors and I've found this one which seems to fit my needs: http://www.onyougo.com/antec-firewire-internal-adapt
_iph3w0771369.jpg It has the following layout: 1. TPA + 2. TPA - 3. Ground 4. Ground 5. TPB + 6. TPB - 7. +12V 8. +12V 9. Key (no pin) However there's one thing that makes me doubt... My front panel connector does have 9 holes which will fit upon the pins of the adaptor, BUT! There are only 8 wires attached to the holes, as in, one hole is completely EMPTY. It corresponds to the +12V pin, so when I connect the adaptor to the front panel only one +12V pin will actually be connected, the other won't do anything at all... Is that normal??? Can I use this adaptor without being afraid of frying my PC??? Thank you very much for your time!!!
